QA1 K member for my vert
So im looking around at some k-members and it seems Qa1 is pretty cheap altho i have some concerns about them moving my wheels forward and them rubbing when turning or something so i want to see if any1 with a new edge has installed one with stock A-arms i really dont want to buy it and find surprises during the installation thank you!
My friend and I installed one on his 02 GT a while back. The stock A-arms need to be grinded down around where the bushing is if you want to use those. Also, the car will sit very, very low with the springs you have in there now. I recommend either putting the stock springs back in, or getting mach1 or bullitt springs. You will also need a bump steer kit to go with it as it does move the wheels out and will mess up your toe angle a good amount. IMO, I would say either get the whole coilover kit with it this way your not having to modify factory parts to work with it, or just leave the stock K-member in. It is only a 20 lb weight difference if I remember correctly.
So if I get the kmember and their a arms and an upr coil over kit I should be good? Will kyb gr2 work for the upr coilover kit? Money is tight so I need everything to work perfectly thanks for your reply
Matt's 95 Stang
Oct 5, 2015 07:16 AM
