getting a procharger
I'm probably going the procharger route and was curious as to what other additions I needed to ensure that everything will be running smoothly. I'm planning on just buying the basic kit (It's like $3,750) online.. just curious as to what else I need. I know I'll need it re-tuned immedietely.
RE: getting a procharger
I was looking at this kit -> http://shop.store.yahoo.com/hopup1/prsusyfomugt.html
Thanks guys
Oh also ... I was curious... I might get the 12psi kit since it's only a bit more and just run it at 8 until I have the money to forge the internals. Now my question is -- what do I need to replace to make sure I'm safe running 12psi?
Thanks guys
I asked a similiar question a week ago about what i needed to do for 12-14psi, here is a link to the responses I recieved. hope it helps
https://mustangforums.com/m_623811/tm.htm
Dont take my word on it but I would assume just a tune. If you get the kit I assume it would give you the correct injectors and MAF. I know with the 9 psi intercooled KB kit you get basically every thing you need and they have a tech guide to help you ugprade and see what you need and what they recommend. Prochargers and vortecs i have no idea about thier kits but I assume if it was a kit it would include all the nececarry things except the tune
no the kit doesn't include everything that you'll need. you'll definately need injectors or you'll lean the engine out, not sure about the MAF. hopefully someone with a supercharger can give you some advice here, or PM some people that has one in their sig.
