What can knock in the clutch area?
Pretty simple question. I have had a knocking that has haunted my car since I got it. It's not in the motor, I have checked and changed everything possible over two DIFFERENT motors and the knock remains. I can put the car in any gear and let out on the clutch 3/4 of the way and the knock stops. If the clutch is all the way in, or all the way out, it knocks. If it's in gear, or out of gear, it knocks. Only when it's in gear and that 3/4 zone does it stop.
So, my question is what can make that kind of noise in the clutch/bell housing area?
Here are a couple of videos.
http://www.youtube.com/watch?v=QWvVzFBT6WI
http://www.youtube.com/watch?v=JPLAaf-liTI
Doesn't sound like it's anything to do with the clutch to me. I had the same problem with mine for a while, it eventually went away. Sounds like it's something internally on the engine to me. I would take a stethoscope and listen above each cylinder, then you can determine which one is knocking (if any).
If you're curious, here's what mine sounded like.
http://www.youtube.com/watch?v=YdZVolqfSQA
Yours sounds like a rod knocking. I don't know how it cleared up on it's own, but I am reasonably confident that it will return.
Now. I have stethoscoped every possible place on that block. I have disabled cylinders one at a time, I have changed the lash adjusters, I have rebuilt and double checked the rods/mains. I have rebuilt the timing system and even switched to a different brand of spark plug and NOTHING has affected this knock. My oil pressure is fine, it's not a broken heatshield on the exhaust or a loose catalytic converter. I have checked every possible thing except the clutch.
I just tested it again. Chocked the rear tires, set the emergency brake and put it in 5th gear. Release the clutch and keep the revs around 1000K RPM, which is where it knocks the loudest and it completely shuts up when the clutch is 3/4 of the way out.
Pilot bearing is new and the TOB is newish. I am just sick of going on a goose chase which is why I am asking here before I pull the tranny.
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
junior04
09-28-2015 10:53 AM
