CEL p1151
says its a lack of 02 switches-bank 2 sensor 1
explanation could not adjust fuel trim because of a lean or rich condition
probable causes:
fuel pressure high or low
maf sensor dirty or bad(i just cleaned it)
vacuum leak on engine(just checked doesnt seem to be any)
leaking fuel injector or fuel presure regulator
what could it be like specifically?
probable causes:
just as it says, did you clean it with maf cleaner? i found that works the best. then check for vac leaks, you can grab a can of carb clean and spray around the hoses, if the idle changes there's a leak in that area. I doubt it's a fuel injector/regulator.
no exhaust leak
my car has 175k on it should i just replace the fuel injectors? would i be able to see gas leaking out if an injector was leaking?
bryan616fl
Jan 25, 2019 09:07 PM
