Decision time
I need yalls expert opions I have a lil over 800 bucks should i 1)buy steeda udp and start some suspenision works (such as upper and lower control arms and subframe connectors) or 2)save up for some cams. What would yall do in my place? whats better for the long run yall think? i usually just street race.
Don't do the cam if u plan on supercharging later, I say suspension, make the car handle the mods u've equiped it with y not some adjustables 365 for those upper and lower rear control arm kit 300 for that so ure at 665 total a few hrs labor( do it your self not hard) and save the extra $$$ for the next mod or Stainless Steel brake lines, that's my ideas
K
K
Hey ducky, is you car a 5 speed or auto?? If you have a auto, I would suggest that maybe you get a shift kit, and stall converter!! You can get a shift kit for $100 or so and on e-bay look for a stall, and you can pick one up for a $2-400, that would leave you $3-400 for the install. If you have a 5 speed, I would get the Steeda UDP's, sub-frame connectors, upper/lower control arms, before you get the cams, so when you do get them you can put that power to the ground!!
