Its blown on the drive side..I wanted too know would i have to unbolt the tranny from the motor to left it up? Or would there be room to get too it if i didn't.
yup, you will only need to lift it up a few inches. I woud remove the bezel around the shifter as well to make sure that the shifter has enough room to be raised a few inches. you will prob have to remove the tranny brace also which is a mere 4 or 5 bolts. Other than that it should be pretty straight forward.
