Squealing brakes
Squealing brakes
Put on new pads and bedded them properly but they still squeal when i start applying the brakes and when i am getting off the brakes but not when i am holding pressure on them while slowing down. Any Ideas?
Same thing is happening to me... i got new front pads/rotors and put on professionally(im lazy) and at first they were good but couple days later they started squeaking under light pressure... Not sure what it is???
I have the same problem, and no they are not cheap pads/rotors. Try googling 'squealing brakes' and you will find out there are many suspected causes and the usual answer is 'I don't know why'. I wish I had kept the link to the article that I read... it was very informative on this.
As Vanquish asked, did you do anything with the rotors?
If the rotors were not turned to an almost perfect finish, even if new, that could be a cause. If the brakes/rotors were not correctly broke in, that could be a cause. If you installed the brakes when the moon was in the wrong phase, that could be a cause.
02stang... I would take it back to that shop. They may not do anything for you but then again they may redo the job for you.
take them apart again and see if the pad has shifted. the first and only time i had my brakes done by someone else they f'ed it up. he did not line the little bumps on the back of the brake pad up properly and they shifted. if you have ever done brakes the you will know what i'm tlaking about. so my vote is they shifted if not then you have a phantom squeak lol
Thanks for the ideas guys im going to take them back apart this weekend and yes they were cheap pads but they were the same thing i had before and they never squealed before and no i didnt turn the rotors we have a lathe in shop but I was in a hurry I have never had to turn rotors on any other cars ive changed pads on but idk we will lean more when i take them apart.
Permatex Disc Brake Quiet--I never install brake pads without it, even if they come with so-called anti-squeal shims. If so, use the spray on the pad backing plate inbetween the plate and shim, and on the shim where it will contact the caliper or piston.
