Oil Temp gauge dont work???
Old May 3, 2010 | 09:34 PM
03SonicBlue_GT's Avatar
03SonicBlue_GT
Default Oil Temp gauge dont work???
i have a 03 gt and my oil temp gauge doesnt work. do you guys think it is just the sensor in the block?
Old May 3, 2010 | 09:54 PM
vanquish's Avatar
vanquish
Mine works intermittently. I was thinking of changing the sensor right around the oil filter too.
Old May 3, 2010 | 10:19 PM
0949er's Avatar
0949er
that's really all it could be I would think. Have you visually inspected it for damage?
Old May 4, 2010 | 04:43 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
There is no oil temperature gauge on a new-edge GT--unless you have some after market thing someone added?
Old May 4, 2010 | 05:05 PM
03SonicBlue_GT
haha ya just relized it was oil pressure haha dumba**
Old May 4, 2010 | 05:08 PM
a_penquin's Avatar
a_penquin
its either the sensor, wiring, or cluster. Check the sensor first and the wiring around it. Replace sensor, if all else fails go aftermarket.
Old May 4, 2010 | 05:10 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
As to your original question, if you have driven more than 5 miles since the gauge stopped working then it's either the sensor or the gauge--the engine would have seized by now if there were no oil pressure...
Old May 4, 2010 | 05:23 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
My buddies car had a broken wire right around the fuse box under the hood. so double check the wire coming from the sender before replacing the part
Old May 4, 2010 | 06:04 PM
03SonicBlue_GT
ya it works fine i just noticed everytime i started it it just went to the same spot hahaha. i was thining it was oil temp lol. u no like ur water/coolant temp gauge going up as car gets hotter thats what i was thinking about the oil temp. but then i realized it was oil pressure. so it was just a dumb misunderstanding of me.
Old May 4, 2010 | 06:45 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
It always "goes to the same spot" because it's an idiot gauge--the pressure "sensor" is really just a pressure operated switch that closes when the oil pressure is greater than 6psi. When the switch is closed the gauge goes to more or less full scale.
Most mass-produced cars that have oil "pressure" gauges work the same--as it reduces warranty calls from jerks that don't know anything about how engines work. They freak out because the oil pressure "varies all the time", is "high/too high when the engine is cold", "takes a while to come up", etc.
Mazda put a dummy o/p gauge in the Miata in '94 in response to such issues.
djbigskrilla
Sep 20, 2022 01:04 AM
Spiral534
Oct 6, 2015 04:31 PM
yurizx6r
Sep 7, 2015 06:40 PM
jjwinel78
Aug 17, 2015 03:34 PM
yurizx6r
Aug 11, 2015 07:50 AM
