TFS valve guides...
Old 05-09-2010, 09:52 PM
NinjaMonky
NinjaMonky's Avatar
Default TFS valve guides...
So check this, my new tfs heads are bad *** i love'em got a stg3 port job on them but during the break in, (before dyno n tune) 1 of the valve guides broke.... -_- so got to pull the heads back off, and get some bronze guides. Question, is it possible to pull the heads w/o pulling the motor? I have a forged bottom so pulling the motor the 1st time around was obviously a must. but really the biggest pain is taking off the t-56, its a pain when all you have is a cpl of jack stands.
NinjaMonky is offline
Old 05-09-2010, 10:02 PM
lizzyfan
Underboss
lizzyfan's Avatar
It can be done but a real PITA
lizzyfan is offline
Old 05-09-2010, 11:02 PM
NinjaMonky
NinjaMonky's Avatar
Well I guess ill go ahead n give it a try, if it become to intense ill just have to drop the trans n pull it
Old 05-10-2010, 08:26 AM
03BottleFedGT
03BottleFedGT's Avatar
it can be done, the biggest issue is the hydroboost being in the way you have to remove it to get the driver head off
03BottleFedGT is offline
Old 05-10-2010, 03:05 PM
yamanx
yamanx's Avatar
I did mine without taking the hydroboost off but it would have been easier with it gone. Its not too bad, I removed everything from the front of the motor and the radiator so that I could stand in front of the motor, that made it easier to actually pull the heads.
yamanx is offline
Old 05-10-2010, 03:55 PM
NinjaMonky
NinjaMonky's Avatar
That's good to kno, removing the hydroboost loks lik a bitch.
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
svfetter
10-05-2015 11:39 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: TFS valve guides...
