rpm shift points using the predator
Old May 8, 2010 | 05:34 PM
MaKaVeLi's Avatar
MaKaVeLi
Default rpm shift points using the predator
i want to make sure that my rpm shift points are perfect,
so please can any body give me he perfect shift point for my car with the mods in my sig?
shift points: 1-2 :
shift points: 2-3 :
shift points: 3-4 :
thanx alot !
Old May 8, 2010 | 07:45 PM
smythge's Avatar
smythge
is your transmission stock? On a stock valve body the 1-2 shift takes about 1 second to happen with 3.27 gears your motor will rev about 1,000 RPMs a second so you need set the shift point below where it is actually going to shift. With 3.73s your motor revs up faster so you will need to reduce the 1-2 shift even more or you will hit the rev limiter at WOT.
I have 4.10 gears and a blower I have my 1-2 set to 4,750 actually shifts at about 5,800, I have my 2-3 set at 5,700 and my 3-4 at 5,300. You need to play with it a little to find the best shift points for your car.
Old May 9, 2010 | 02:48 AM
MaKaVeLi's Avatar
MaKaVeLi
i just install 3.73 gear, my transmission is stock, so what you suggest for my case? ( before i play with it cuz i dont want to do somthing stupid)
Old May 9, 2010 | 08:57 AM
smythge's Avatar
smythge
I would read through this write up 2/3 of the way down it explains the 1-2 shift.
http://tccoa.com/articles/tranny/tra...on/page6.shtml
As far as setting your shift points, I would start with stock and see how it does and gradually drop it down.
Old May 9, 2010 | 02:55 PM
MaKaVeLi's Avatar
MaKaVeLi
this is my set when i checked the settings in the predator
shift points: 1-2 : 5950 (was 6100 !)
shift points: 2-3 : 5700
shift points: 3-4 : 5700
any suggestion? somthing good but wouldnt hurt the car?
6bangr
Feb 15, 2016 07:40 AM
Oct 7, 2015 07:02 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
