engine stays hot
Old May 23, 2010 | 05:49 PM
96meangreengt's Avatar
96meangreengt
Default engine stays hot
Does anyone elses engine stay hot after it been sittin for a long peroid of time. The gauge usually stays around the M and R when driving so I dont think its running hot. Today I got home at 12 noon and went outside to put my new belt on at 3pm. and the engine was still really hot. Got in the car and turn the key on and the temp gauge showed cold but the engine was still very hot to the touch.I thought aluminum dissapates heat faster than cast?
Old May 23, 2010 | 06:37 PM
hot sauce's Avatar
hot sauce
theres not an issue with your car that normal. your engine will not get ice cold in a few hours. and yes aluminum does cool down faster but your engine is a iron block with aluminum heads.
Old May 23, 2010 | 07:37 PM
96meangreengt
oh ok for some reason I thought these were all aluminum, just got the car so learning new stuff everyday. Just was concerned because the upper radiator hose was so hot I couldnt even attempt to put the belt on, almost burn your skin hot.
Old May 23, 2010 | 07:52 PM
DreamerGT's Avatar
DreamerGT
If you leave the hood open the engine will cool faster for you to work on it.
Old May 23, 2010 | 08:47 PM
hot sauce's Avatar
hot sauce
+1^ on that one
Old May 23, 2010 | 09:37 PM
SVTeeshirt's Avatar
SVTeeshirt
as long as its not 90 degrees and you're in the sun, yes that helps.
Granatelli Sales
Jan 20, 2020 12:34 AM
mdj89
Sep 6, 2015 11:08 PM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 04:12 PM
