Suspension
Old Jun 10, 2010 | 10:18 PM
deviousgt's Avatar
deviousgt
Post Suspension
What is the difference between camber bolts and plates will the bolts do the same job the plates do?
Old Jun 10, 2010 | 11:12 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Camber bolts will give you +/- 1* of adjustment and depending on the CC plates, you can 1 or 2 more as well as some caster adjustments (good for wider wheels)
Jazzer
Old Jun 27, 2010 | 10:59 PM
deviousgt's Avatar
deviousgt
so if im installing lowering springs will the camber bolts be ok?
Old Jun 27, 2010 | 11:01 PM
defconfire's Avatar
defconfire
It really depends on how much you are going to lower it, you can get away with just camber bolts as long as its not an insane drop.
Old Jun 27, 2010 | 11:13 PM
Stang9946's Avatar
Stang9946
I believe if you go anything more than a 1 1/2 drop you really should have them.
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
