Outter A pilar
Outter A pilar
Anyone have any info how to remove the outer A Pillar body pannel?
I bought a new one do to crack and had it painted the same color as my Mustang.
Guess my question is how to get to the 5 screws that hold it on from inside of car.
I see up front has clips and one nut that is behind fender.
If anyone would have a picture description of removial would be much help.
Thank You
Thank You
Yes, I had to replace mine for the same reason.
The screws that hold in on are behind the window/door gasket. You will have to remove the gasket by simply pulling out of the track. Then remove the gasket track, you will see the torx screws for this. Once you remove the track you will see the screws that hold the trim piece on the car.
Was kinda wondering how to get to those screws.
