after o re build my auto tranny i faced a problem which is theres lag in the 2nd to 3rd shifting, at the begining it wont shift unless i remove my feet from the pedol and somtimes it shift at higher rpm ( more then 3 rpm) and shift hard and wierd ! i replace the valve body and still the same, i took it to the garage to try to find out he problem he opened the trany to check if there is problem but every thing seems fine ! so whats the problem ?? is it about tunning? or somthing els should be replaced ?
yes , i did replace it and still the same, i cant remove the tune because its a cammed car
Did the transmission shift fine before the rebuild? Did you change the transmission settings in the tune at all? Is it a stock torque converter in the car? Had the transmission been modified at all before you had it rebuilt? Do you have a shift kit in it? If the answer to those questions are no, I would say it's mechanical.
the transmission shift fine before the rebuild, all other Q`s : no
When you brought it back to the shop, what exactly did they check? If I had a stock tranmission that shifted fine, got it rebuilt to stock and now it won't shift I would bring it back.
