Blew out a plug
Blew out a plug
*sigh*
Whelp, apparently I blew a spark plug out of the head of my 420 rwhp 2000 Mustang GT.
Two options from the shop; either a helicoil, which will cost in the 300 range (rough) or pull off the head and replace it, which is 9 hours of labor and EXPENSIVE.
I am leaning towards the cheaper fix, especially because I only put a thousand miles a year on the car max and I am a teacher and make crap money
Anyone have any experiences with this sort of thing that might be able to offer any advice or info that might help?
Thanks!
Thanks!
common problem thankfully has not happened to my 02 yet. i know that the ford dealer is used to dealing with this issue. may want to check with them. then again a set of TFS twisted wedge heads...... just food for thought!
I'd helicoil it to get you back on the road quickly without breaking the bank.
and +1 to what Cliffy said about torquing plugs properly.
If you torque one thing on your car with a torque wrench make sure that its your plugs.
IIRC its 11-15 ft/lbs depending on the year and vehicle.
I always torqued mine to 13 ft/lbs and I would put a tiny drop of diff fluid on the plugs threads, I found that works better than anti-seize.
Everything you wanted to know but were afraid to ask:
http://www.modularheadshop.com/Articles/timesert.htm
^^ that doesnt make me feel very good about my car anymore lol. I have never used a torque wrench on the plugs, but I did use antiseize, and was very "gentle" putting them back in. In a hypothetical situation, what would happen if he used a helicoil, and it blew out again in another year>? Is the head then not repairable? Or just not repairable with a helicoil again-now requiring it to be removed and machined?
