Degreeing Cams
TFS crank sprockets, best thing since sliced bread. As noted you need to lock them together via a welder or roll pin as the rear gear can break the crank keyway (a design problem from Ford actually, these gears are patterned after the original 91-98 2 piece gears) I have measured a few sets of these and they are always dead on accurate no matter which position you use. I was pretty impressed with that to say the least.
