muffler sizes
Old Aug 13, 2010 | 08:04 PM
stangcoupe1970's Avatar
stangcoupe1970
Default muffler sizes
I ordered some mufflers from my local parts store, and I got 2-1/4 in/out, is this correct or do I need the 2-1/2?
Old Aug 14, 2010 | 02:53 AM
Drag5.0mustang's Avatar
Drag5.0mustang
From: Parrish,Brandenton,Tampa,Florida,Gratiot Michigan
I think its 2- 1/4
Old Aug 14, 2010 | 02:59 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
I am curious as to why you do not simply measure the tail pipe on your car, so as to resolve this profound dilemma?
Old Aug 14, 2010 | 09:50 AM
stangcoupe1970
I thought the tailpipe was a larger diameter.
Old Aug 14, 2010 | 03:18 PM
Drag5.0mustang
+1 on this... It is bigger...
Old Aug 14, 2010 | 04:07 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
If you measured them, and it's the stock pipe, you would have found it to be 2-1/4" outside diameter (OD). Both the stock mid and tail pipes are 2-1/4".
If you don't have a caliper then just wrap a string around the pipe and make a mark across the string where the ends crossover. Measure the distance between the marks, the is the pipes circumference--divide that by pi (3.1416) and the result, rounded to the nearest 1/4", is the diameter.
Exhaust pipe is sold by the outside diameter, in 1/4" increments; mufflers and such are designated by the size of the pipe they fit on to--so, if you have the stock tail pipe you got the correct mufflers...
FivePointToTheOh
Oct 2, 2015 04:09 PM
Demodulates
Sep 18, 2015 11:14 AM
Sep 10, 2015 08:39 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Webster454
Sep 7, 2015 04:59 AM
