Grill delete hardware?
Did anyone's Mach 1 grill delete kit come with hardware? I didn't get squat. I believe there are suppossed to be some sort of clips that clip onto the four posts that pertrude through the bottom. I have no way of securing the bottom of that flat plastic piece to the front bumber. What gives?
Should just be missing some push clips. You can get them at most auto parts stores. I think you need two for the core support trim, and two for the bumper trim. Oh, and two small screws for the Pony Bracket...
Directions? Didn't get them either. I ended up using Velcro, which works just like the double sided tape. I got the kit from Mustangtunig and it was all Ford OEM parts. I'm guessig they forgot to throw in the a) clips, b) double sided tape, c) both. It didn't help that it was 102 degrees when I was doing this. Anyway, it's on and it looks so much better than that honeycomb crap that was on there. Well worth the $60.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
