cobra caliper help
Old Sep 16, 2010 | 04:08 PM
hpwrestler220's Avatar
hpwrestler220
When you say that the damn car wont move an inch, are you referring to the calipers not closing?
Did you bleed the master cylinder? Same sh*t happened to me. You need to bleed the two valves on the master cyclinder as well as bleed the brakes.
Old Sep 16, 2010 | 07:13 PM
04BlueGT's Avatar
04BlueGT
Let us know how it comes out. I'm having a complete Cobra upgrade installed in just over a week after my gears arrive. I'd like to know what I may be facing.
Old Sep 19, 2010 | 12:27 PM
GTtony's Avatar
GTtony
Originally Posted by medrick
take the banjo bolts back out of the calipers and put 2 crush washers on each side of the bolt instead of 1. should fix it.
OK PROBLEM SOLVED.
The washers that came with the new bango bolts are only half as thick. and the directions i used never said to double them up. When i first attempted merdicks recomendation. the bolts on each side would'nt seal and leaked fluid. so i drove down to my ford dealer and they hooked me up w/ OE thickness washers. I nstalled them to SPEC torque (30lbs).
So FYI to all who upgrade to 10 anniversary front calipers use Fords bango bolt washers only.
WHO KNEW A WASHER COULD SEIZE UP ONES FRONT BRAKE CALIPERS.
merdick was indeed correct. thank you sir and all who dropped their .02
Old Sep 19, 2010 | 05:58 PM
hpwrestler220
You should have told us that it was leaking from the start! You woulda have seen the brake fluid all over the ground. We coulda told you it was the washers instead of us all guessing!
The washers that came with my brakes worked just fine!
Glad you fixed it...
Old Sep 20, 2010 | 11:35 AM
GTtony's Avatar
GTtony
No no man the washers only leaked a bit till and only until i tried doubling up the cheap washers the banjo bolts came with. they DID NOT leak when i used one on each side. nor do they leak now that im using one OE Ford washer on each side.
I tested my new brakes a few times and the same day i fixed them just in time to go to California Speed way's PM drag racing event.
I ran 14.6 @ 100 mph, then 14.2 @ 99 mph then, changed nitrous jets to 125 shot and my tire psi and ran 13.7 @ 102. not bad for a heavy GT VERT.
Old Sep 20, 2010 | 09:31 PM
medrick's Avatar
medrick
awesome. glad it worked out for you. its odd they are too thin...
Old Sep 22, 2010 | 01:46 PM
04BlueGT's Avatar
04BlueGT
Glad to hear you got it fixed. My Cobra brakes should go on next week, along with 3.73s, bearing, and diff cover.
Nov 10, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Dan04COBRA
Sep 30, 2015 11:46 AM
maestro1024
Sep 21, 2015 02:40 PM
Sparks_88
Sep 8, 2015 01:06 PM
