need help with p1000 code.
Old Oct 1, 2010 | 04:43 PM
98redstang's Avatar
98redstang
i was hoping youd come on here lol. Well i can do wiring. ANd i have an o/r h pipe so i want have to alter from the instrustions. So if i make them itll make it read that the cats are workin? OKay just looked at the sticky or whatever you wanna call it. I can do that no problem my other problem is my egr is deleted. But he said i only need 4 of the readings to read and he'll pass me. So i could make the mil elimintors and just run a tune with the egr shut off and thatll be the only one im missing so no biggie correct?
Old Oct 1, 2010 | 05:38 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
There is a better than 95% chance that they will work, for some reason there seem to be certain EECV strategies that do not like the MIL Eliminators--I do not know why and have never found a pattern to it (older/newer, certain box codes or whatever).
The shop manual says that "some models" use the frequency ratio method I mentioned on the DIY page, but I have never found any documents indicating the new-edge Mustangs used that method--IDK...
Old Oct 2, 2010 | 07:30 AM
piledriver's Avatar
piledriver
Banned
Originally Posted by uberstang1
Since I did my motor swap my CEL has been on permanetly reading a fuel pump relay code, it won't clear or anything. My soloution was pull out the bulb for the check engine light, that will work for the PITA garage.
I don't think that will work. The computer will detect it even with the bulb pulled. The bulb is just an indicator that something is wrong, the problem won't go away just because you remove it.
Old Oct 2, 2010 | 08:32 AM
98redstang's Avatar
98redstang
okay well its worth a shot.
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
mrtrodonet
Sep 19, 2020 03:12 PM
firecoyote
Sep 27, 2015 02:37 PM
zachary1988
Sep 4, 2015 03:04 PM
