Cylinder Missfire
Old Aug 15, 2005 | 07:19 PM
Captain Drew's Avatar
Captain Drew
Default Cylinder Missfire
I recently threw an engine code saying that I was having a missfire in cylinder 4 on my 99 GT. I went in and replaced all my spark plugs and decided to change the coil packs betweek cylinders 3 and 4. The problem is still occuring but feels slightly different, it could be that the missfire has switched to cylinder 3 but is throwing the engine balance off differently than when the missfire was in cylinder 4. I got it to throw another code but haven't checked it yet. Could it be the coil pack? What is the life on them? Any info on this would be greatly appreciated. Thanks!
Old Aug 15, 2005 | 07:34 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Cylinder Missfire
Worst thing you can do is go in and throw parts (money) at a problem like that without further investigating. Since you've already taken the time and effort to replace the plugs and coil packs of the offending cylinder(s), it could be fuel related (injector) or perhaps a wire going to the pack is bad. I don't have a GT so I've never bothered to check how to test the coil packs incoming voltage but that's a good start. Also, you may want to run a fuel system cleaner through your gas to help clear out any junk in the lines or injectors. You could also test the Injector itself. They sell the injector test lights at auto parts for like 15 bucks and it will show you if the injector is not firing properly or weak.
Old Aug 15, 2005 | 07:36 PM
PipsBlackStang's Avatar
PipsBlackStang
Can you feel your engine misfiring? I pulled a misfire one time and since the o2's werent getting dirty I figured the injector was jacked up and thats what it was. I didnt even feel the misfire when that was happening and running on 7 cylinders....weird.
Old Aug 15, 2005 | 09:44 PM
04BlueGT's Avatar
04BlueGT
It could be....
Coil pack
Plugs
Wires
O2 sensor
Crankshaft position sensor
What are your mods and have you made any changes recently?
Old Aug 15, 2005 | 09:53 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
Have you washed off your engine here lately? Water can seep pars the plugs believe it or not and cause several misfires.
Old Aug 16, 2005 | 01:01 AM
Jglisson's Avatar
Jglisson
What a bunch of misinformation! Why don't some of you do your homework before you spout of nonsense.
He has a 99 GT which does not have wires, and an O2 Sensor will not cause a misfire.
Cylinder # 4 is the passenger side plug all the way in the back closest to the fire wall. # 4 and # 8 are the first ones to go because of the higher heat temperatures in the rear of the engine bay. Luckily they are easy on the Mustang...try reaching those plugs on any F150 or Expedition.
Please explain how you replaced the coil BETWEEN 3 and 4. Each spark plug has its own coil. The cylinder numbering order is whacky on the Fords, you may have replaced the wrong one. Any improvement you noticed is from having a new spark plug in there. Check the codes again and see what you've got.
General rule of thumb:
Coil packs usually act up at low RPMs under a load (usually around 1200-2000rpm). Injectors act up under heavy throttle at higher RPMs. You could putt around town all day and never know you had a bad injector.
Old Aug 16, 2005 | 01:24 AM
04BlueGT's Avatar
04BlueGT
Okay, here we go....
One, they do not have 'spark plug' wires in a traditional sense, but they have wires none the less. As such, they are subject to degradation by under-hood heat, which leads into one of your hypotheses.
Two, the crankshaft position sensor WILL cause misfires, but those misfires will remain on that cylinder. AND, it can happen at sustained rpms ABOVE 2400.
Three, we didn't add the bit about injectors, but since a previous post addressed it, why reiterate it?
Four, my first (of many) mustang was built before most folks on the forum were born, so save me the recriminations.
Five - Not one person claimed to be an expert here. We are all here to offer ideas and opinions to assist others, based mostly from personal experiences. AND not one person made suggestions which would cause him to suffer engine damage or incur further expense. To wit, I asked for a list of modifications and which ones, if any, may have been performed recently.
Old Aug 16, 2005 | 12:54 PM
MarcusM's Avatar
MarcusM
Anyways..
When you replaced the coil packs did you replace the boots on them aswell. I have a 99gt, and I have had a couple problems with the boots themselves, not the coils (yet)... Yeah, I have never heard about the stock "wires" ever having a problem, unless there was an engine bay fire, or something drastic happened. If you haven't switched the boots, and just the coils, try that. When mine was misfiring it was pretty ruff, even being just one cylinder.
Old Aug 16, 2005 | 07:10 PM
Jglisson's Avatar
Jglisson
ORIGINAL: 04BlueGT
One, they do not have 'spark plug' wires in a traditional sense, but they have wires none the less. As such, they are subject to degradation by under-hood heat, which leads into one of your hypotheses. Never seen 16g wire "degradate" by heat...but if you insist.
Two, the crankshaft position sensor WILL cause misfires, but those misfires will remain on that cylinder. AND, it can happen at sustained rpms ABOVE 2400. I never argued that a CPS would cause a misfire, reread my first reply.[/b]
Four, my first (of many) mustang was built before most folks on the forum were born, so save me the recriminations. Congrats...[/b]
Yea...but so typical of most posts lately (not yours by any means), are flooded with random ideas that make no sense and have no merit. The replies on this board are usually just down right ignorant.
How many posts do we have to have about gears? Over and over again with the same stuipd replies? How many questions do we have to have about PI intakes with the same freaking answers?
And such wonderful responses! I will tell you what, according to the majority...O2 sensors and a bottle of fuel system cleaner will solve anything.
Old Aug 16, 2005 | 07:56 PM
Captain Drew
Ok here goes... the only mods I have currently are a bassani X-pipe and a K&N FIPK. I switched the coil packs AND the boots when I did my spark plug replacement. I'm gonna replace the boot to see if that clears things up and if not the coil goes next.
