h/c or fi?
actually the guy that made 355rwhp through an AUTO ( if it really matters in our modern-age) on a stock 01 cobra short block and like generic stage 2 cams ( CMS i think)
to the guy that said port the TF heads, that would probably decrease overal power and wouldnt even help the peak numbers by much.
if ya wanna keep a low budget, flycut a set of 4v pistons and get custom ground cams with the "stock" TF heads and a edelbrock intake and i would almost promise 350-360rwhp
lol hate to argue but the ones I've seen were stage 2. Is it really that hard to believe? If you can have a cam + bolt ons = 300ish and when you add ported pi heads (220ish cfm) you get what from a traditional h/c 2v? 320rwhp? Usually less isn't it? Then you take a set of tfs heads that are 240cfm and depending on the head size you choose you can either raise or lower the c/r. I think between adding 20cfm and uping the c/r, 340-350 sounds about right. But I wouldn't invest in a set of tfs heads unless your going for big boost to put down some big #s.
lol, blower and cams? im not making a race car out of mine, just something that has a good feel all around, maybe some 373s with the h/c setup. Realistically I would be looking for 330-350 out of a h/c setup, and 380-420 with a blower. Not hard numbers either way.
^^beleive me when you put those heads and cams in you'll want more. I would go with the best bang for the buck. My setup cost me 2100 bucks (including Intercooler & Power Pipe). With the mods I had on my car (before the S/C) I paid about the same thing and gained, what 20-25 RWHP. Not telling you what to do but I wished I had listen to some of these guys 2 yrs ago.
So what would be cheaper and more reliable? This would be for my 01 so I already have the intake and I'm thinkin' going with the new twisted wedge heads from trick flow plus a stage one or 2 cam. I know a superchargers has been the sure fire way to go with a 2v, but theses new heads seem to be getting 2vs in the 350rwhp range. Thoughts and opinions?
heres the vid that got me thinkin.
http://www.youtube.com/watch?v=CmoSqpddI3o
