Clutch Problems
Just bought a 2001 GT. Was in a collision and sat for a while. I got the car cheap when i picked it up just drove it right on the trailor. Has adjustable clutch cable, stage 3 clutch, Was gonna drive it down the street b4 i tore it down and cannot get it in gear. Grinds in 1st every single time and will not go in any other gear. Ive adjusted clutch cable all over the place but doesnt help. Only way you can get it in gear is to shut the car off and put it in gear. clutch, throwout bearing?? Whats the problem and what all should i try?
Thanks
Thanks
U can shut if off. goes into first perfectly fine off, start car and car takes off fine then try to shift into 2nd and either u have to slam it very hard or it doesnt go. try to go into first and just grinds. shut it off put it right back in first and pull it back in shop. thats all i can get out of it.
¹ - Lifting the clutch pedal with your toe is the proper procedure for activating the semi-automatic clutch cable adjuster. Download an owner's manual here, and read it...
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
