having clearance problems.
Old Nov 8, 2010 | 12:28 AM
stangc83's Avatar
stangc83
Default having clearance problems.
Well i just bought some bf goodrich 295/35/18 and got them installed. Well i am having some clearance problems with clearance. I live in Houston and for those of you who live there, know how that roads are, well i am rubbing whenever i hit a bump. So i bought some Tokico shocks the HP sports, Do you think that this will fix the problem. My car is lowered 2 inches also.
Old Nov 8, 2010 | 01:26 PM
Z28KLR's Avatar
Z28KLR
Not sure if those shocks will lift you back up much if any at all, I've heard that Bilstien's lift like 1/4" sometimes. You're probably going to have to get your fenders rolled.
Old Nov 9, 2010 | 07:45 PM
bbcobra's Avatar
bbcobra
the lowering of 2 inches is your problem. rolling the fenders is probably your only option.
Old Nov 9, 2010 | 10:34 PM
hpwrestler220's Avatar
hpwrestler220
I'm lowered 2 inches and i had to roll my fenders... Sh*t, i had to roll them when i was lowered 1". Stupid progressive rate springs
Old Nov 10, 2010 | 11:39 AM
Case's97GT's Avatar
Case's97GT
Yes you are definitely going to need your fenders rolled.
Old Nov 10, 2010 | 11:42 AM
SilvrStang's Avatar
SilvrStang
Have you take n out your quad shocks?>
Old Nov 12, 2010 | 06:24 AM
stangc83's Avatar
stangc83
what do you mean taken out my quad shocks? I just put on my tokico shocks. they are a lot better ride, but when i hit bumps that i dont realize are coming up i still scrape a little.
Old Nov 12, 2010 | 08:04 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Quad shocks are the ones that are mounted laterally from behind the rear tire and up to the frame going back. They are generally removed when a new set of LCA's is installed. You can do them anyway, but a new set of LCA's* will somewhat "address" the slightly looser feel some get when quads are removed.
Jazzer
*not just ANY old LCA's.... hit up my suspension guide for what type and why
Tivo304
Aug 28, 2023 12:19 PM
CS2007
Jun 25, 2019 09:45 PM
ChampInSD
Oct 2, 2015 04:55 AM
zanemoseley
Sep 6, 2015 12:58 PM
vincep99
Aug 30, 2015 11:42 AM
