replacing clutch yourself?
Old Dec 12, 2010 | 07:10 PM
AmericanBred_4.6's Avatar
AmericanBred_4.6
Default replacing clutch yourself?
i wanna replace my stock clutch with a stage 2, ive looked up how to i have dont countless hours of work on cars including my own got plenty of tools torches, grinders, welders everything almost and i was jw what little secrects were involved with tackling a clutch job......u kno those little tid bits that make the prodject go by that much quicker, i do not have a lift tho
Old Dec 12, 2010 | 07:11 PM
AmericanBred_4.6
oh yea its an 04 gt 5 speed
Old Dec 12, 2010 | 08:06 PM
watman02's Avatar
watman02
sorry theres really no secrets the one thing I would say is remember to dissasemble the shifter area(trim take the boot off and you may need to remvoed the shifter as well.) and when reinstalling fallow the procedures of alighning the clutch plate. and if the input shaft on the trans seems to not want to go in when reinstalling the clutch pull the trans back out and check it over to make sure everything is properly lined up and not binding it should just fall into place (dont pull it together with the bolts!!!!!!!!!cus if yo have to theres somthing wrong!!!)
Old Dec 12, 2010 | 08:27 PM
AmericanBred_4.6
i heard that the starter is hard to finagle out of there....one guy used like 4 ratchet extensions to get it off.....idk if thats is needed tho
Old Dec 12, 2010 | 08:56 PM
BraMas's Avatar
BraMas
starter has to come off and the top bolt can be a pain in the *** to get off. The trick is to take off the passenger front tire and use a couple long extensions thru the k-member and the top bolt is easy to get out.
Also the top bolts on the bell housing can be a pain in the *** if you take the trans crossmember off and tilt the engine and trans down and the bolts are easier to get at. I like to do them first
Old Dec 12, 2010 | 09:11 PM
AmericanBred_4.6
is it possible to get to them without tilting the engine?
Old Dec 12, 2010 | 11:57 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I suppose it's possible, as in most things are, however you have to remove the tranny mount and let the engine tilt anyway to get the transmission out. Here's the removal procedure from the shop manual...
Old Dec 13, 2010 | 05:22 AM
uberstang1's Avatar
uberstang1
Chupacabra
I'm assuming you know you will need a new flywheel or get you're existing flywheel resurfaced.
Old Dec 13, 2010 | 08:58 AM
AmericanBred_4.6
yea i was wondering if i should get steel or aluminum ive heard steel alows you to keep a dd capability what do u guys think?
Old Dec 13, 2010 | 10:41 AM
0949er's Avatar
0949er
have fun with that. The top starter bolt is a bitch.
how do you plan on doing this install? The Transmission is EXTREMELY heavy.... that is not exaggeration
oh yeah and cap off the end of the transmission when you drop the drive shaft so it doesnt spill your fluid everywhere.
