Not sure about the mini race valve but ive got the procharger big red blow off valve and its crazy awesome.
Maybe try searching for some vids on youtube?
yes but a bov isnt the same as a bpv and they wont ever sound the same. the "whoosh" you get from a bov is because your hearing air vented to the atmosphere, not recirculated back through some rubber hoses.
How many pounds of boost are you running? I was under the impression that the bigger procharger valves were for blowers making 14psi and higher.
I have the mini bypass vented to atmosphere running 10lbs of boost and its not that loud, definitely audible but nothing like the procharger big red valve
Yes it is a very bad thing. That fluttering is boost backing up into your supercharger. It can destroy your supercharger. I would replace it as fast as you can. No you won't need a retune.
