Axle Replacement Problem / Need help with LSD
Old Jan 10, 2011 | 05:19 AM
  #21
uberstang1's Avatar
uberstang1
Chupacabra
Originally Posted by Smoothie247
Thought about that. Whats the difficulty on replacing the diff?
Setting up a rear is not for the average DIY mechanic, involves alot of detail as far as shims, pinion depth, etc etc. It would be better to take it to a shop then then risk slappin it together and having the rear howl like a banshee driving down the street.
Old Jan 10, 2011 | 07:36 AM
  #22
cliffyk's Avatar
cliffyk
TECH SAVANT
It depends greatly on your wrench turning experience, access to the needed tools, and how comfortable you are with precision measurement. I have done 3 Mustang gear swaps, and maybe 10 as a lifetime total. It's not rocket science however you will need a 10-ton+ press, and precision depth gauge and dial-indicator, in addition to common tools.
This is one of the best write-ups I have seen.
Old Jan 10, 2011 | 10:11 AM
  #23
BraMas's Avatar
BraMas
Don't go buying a whole new carrier just because you are having trouble figuring it out. I would assume that piece is a lot better than a OEM unit. If your not already a member of the Corral Forum I would go over there and someone will be able to help you. It has members with real good knowledge
Old Jan 10, 2011 | 12:57 PM
  #24
Smoothie247's Avatar
Smoothie247
I'll check out corral form this eve, thx. As far as working on it, I figure i'll replace it as an absolute last resort. Its prob something simple that i'm overlooking. Thx guys
Old Jan 17, 2011 | 02:48 PM
  #25
Smoothie247
So in case anyone runs into this issue in the future....
i took it to a diff shop. They had to take the carrier apart. There was some gunk and metal flakes in between the bearings and shims. The guy I bought the car from didn't install it right. Once they put it back together, the axle spacer slid right in.
was a torsen true-trac btw.
fyi
luke
djbigskrilla
Sep 20, 2022 01:04 AM
Urambo Tauro
Sep 7, 2015 12:47 PM
DrunknRuckus
Aug 23, 2015 10:05 AM
ccwebb
Aug 11, 2015 06:47 PM
philster0306
Aug 10, 2015 11:33 AM
