Trouble with brakes
Old 01-22-2011, 04:06 PM
dhadder1
dhadder1's Avatar
Default Trouble with brakes *may be traction control issue*
Thanks in advance for all the help!!
About eight months ago I swapped my rear end stock for stock. (was faster than rebuilding it) Since then when I brake under certain conditions mainly hard corner braking I get this clicking coming from the right rear side. I can feel this clicking in the brake pedal also. If I let off of the brakes and reapply it will usually go away. It only does it sometimes so it's hard to be ready for it. When it does the clicking I can tell it is not braking properly.
Think it could be a caliper or something with the ABS?
Also it is on an 04 GT.
dhadder1 is offline
Old 01-22-2011, 04:08 PM
zero2005
zero2005's Avatar
did u bleed the brakes?
zero2005 is offline
Old 01-23-2011, 01:43 PM
dhadder1
dhadder1's Avatar
Yeah I did bleed the brakes. That was my first thought but I didn't have to go into the brakes on the swap.
dhadder1 is offline
Old 01-23-2011, 02:11 PM
school boy
school boy's Avatar
the rear calipers are known to freeze up. they may be trying to do just this.
school boy is offline
Old 03-21-2011, 07:14 PM
dhadder1
dhadder1's Avatar
Its been a while on this but here is an update. I recently replaced all of the rotors and pads. I also change out the right rear caliper where the flutter is coming from. But still the flutter is there. Has anyone heard of this happening due to a bad brake hose? But it still feels the same, I hit the brakes and it flutters, I let off and reapply the brakes and it feels fine. Some times it will do it twice before clearing up.
dhadder1 is offline
Old 01-26-2012, 07:33 PM
dhadder1
dhadder1's Avatar
Still haven't found the problem but I found out something else. I jacked the car up on stands and put the car in drive. Once I let off of the brakes it started pulsating. I could put my hand on the brake hose and feel that it was definately coming from the brakes. I also could feel the pulsing coming from the Hydraulic control unit in the engine compartment. I think that is what it is called. It is on the passenger side kinda low in the front. Any ideas or do I need to take it to a real mechaninc? lol.
dhadder1 is offline
Old 01-27-2012, 09:02 AM
Brute03
Brute03's Avatar
you could try swapping the abs sensors from your old rear end and if that helps
Brute03 is offline
Old 01-27-2012, 09:30 AM
Fink
Fink's Avatar
Im gonna say it has to do with the ABS. swap sensors like brute suggested.
Fink is offline
Old 01-28-2012, 03:23 PM
dhadder1
dhadder1's Avatar
does anyone know the ohm reading that the sensor should be at?
I thought I had found something cause when I have the car on the stands and in drive it does all of the crazy noises. when i turn off the traction control the noise will go away. So I thought just leave the trac off but when I drove it the car still does the noises and pulsating when I brake and turn at the same time.
dhadder1 is offline
Old 01-29-2012, 06:47 PM
dhadder1
dhadder1's Avatar
after lots of research on the sensors I found that they are fine. The rear sensors were both reading 1625 ohms. I found that between 1200 and 2000 ohms are good. This is a pain in the butt. I am ready to sell my stang cause of this. Guess it is time to come off the wallett and take it to a shop.
dhadder1 is offline
Quick Reply: Trouble with brakes
