Valve Cover Gasket
Old 02-07-2011, 01:00 PM
sportsguy0502
sportsguy0502's Avatar
Default Valve Cover Gasket
So i was wonder if these valve cover gaskets would fit my 1998 gt, its stock. If you recommend another one, let me know, im not sure if I got romeo or windsor heads.
http://shop.advanceautoparts.com/web...___#fragment-4
sportsguy0502 is offline
Old 02-07-2011, 04:28 PM
bluepony4.6
bluepony4.6's Avatar
Did you count your valve cover bolts? Romeos have 11 bolts and windsors have 13 on one and 14 on the other. Correct me if I am wrong.
bluepony4.6 is offline
Old 02-08-2011, 06:09 AM
sportsguy0502
I did nothing to the engine, the whole car is stock, so im trying to figure out what gaskets i need for the valve covers.
Old 02-08-2011, 07:37 AM
BraMas
BraMas's Avatar
count the bolts that hold down your valve covers,report back and someone will help you get the right gasket.
Someone posted a link for Latemodel resto that has a VC seal gasket and new grommets for $50 that seems like a better option because you get the new grommets also
BraMas is offline
Old 02-08-2011, 01:57 PM
sportsguy0502
I have a romeo head, so any advice on what valve cover gaskets i need?
Old 02-08-2011, 02:41 PM
lizzyfan
Underboss
lizzyfan's Avatar
http://www.cjponyparts.com/46-ROMEO-...6-2003/p/VCG6/
lizzyfan is offline
Old 02-08-2011, 03:11 PM
zero2005
zero2005's Avatar
http://www.rockauto.com/catalog/raframecatalog.php
^^^ bit better price, you'll have to scroll through it though, for some reason it wont let me paste the actual part
edit: make sure you get the 11 bolt version, it shows a picture. if unsure, a 2003 GT has 11 bolts as well and should work, fel-pro brand, part number VS50564R, just under 30$
zero2005 is offline
Old 02-08-2011, 03:18 PM
lizzyfan
Underboss
lizzyfan's Avatar
oem^^^^
lizzyfan is offline
Old 02-08-2011, 07:53 PM
sportsguy0502
I thought we had a DOHC not SOHC?
Old 02-08-2011, 09:42 PM
zero2005
zero2005's Avatar
No, DOHC would be cobra's/mach 1's. DOHC means that there's 2 cams per side (4 total) aka "quadcam" - SOHC is 1 set of cams per side, AKA dualcam.
zero2005 is offline
Quick Reply: Valve Cover Gasket
