Anybody have experience with this engine/head/cam combo?
Hi guys
Im putting together a new engine and wondered if anybody had some experience with this combo.
MMR 900 stroker, Trick flow head, Trick flow intake manifold and MMR stage 2 blower cams.
Going to run it with a Vortech V2 and 3.1 pulley.
at what rpm did you get max hp? max torgue? got a dyno sheet?
What did you set your rev limiter to?
Would appreciate any input from anybody that have tried anything similar to this.
That engine combo will be able to make some serious power with the right blower......but it is also way overkill for a car running that v2 s-trim. You should figure out what your target ET or HP goal is and plan out a build to meet your goal. You could end up saving a lot of money doing it that way instead of just building an engine that is way more than you need.
V2 might be pressed to do 600+. Vortech site states 700+, but that is probably flywheel hp.
The most rwhp I have seen everyone make before they max out the little
Vortech V2 is 600 rwhp.
I would also shop around if you are considering a new engine.
I have heard mixed reviews from people about the Modular Mustang Racing
short blocks.
One of the best modular engine builders in North America
is Modular Performance.
www.modularperformance.com
short blocks.
From Vortech site:
V-2 Si-Trim Std 52000 RPM 22 PSI 1150 CFM 775 HP
V-1 T-Trim HD 55000 RPM 26 PSI 1200 CFM 825 HP
V1 does have the heavy duty gearcase though, but I would expect it to be somewhat noisier also.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
09-08-2015 11:50 AM
M3hunter
09-05-2015 03:42 PM
