DOHC swap for cobra s/c or cobra s/c 2v
Old Feb 24, 2011 | 11:58 PM
A.T's Avatar
A.T
Default DOHC swap for cobra s/c or cobra s/c 2v
i'm thinking about getting a 99-04 mustang gt or an non s/c cobra. i got a s/c for an 03-04 cobra, and didn't know what i should do. would it be cheaper to use the cobra s/c on the 2v or to get a dohc motor and swap it out or spend a little more for a cobra 99-02 and drop the s/c on it? the kit for the 2v adapter is about $2k and would probably need injectors. what other options could i do. i can get a 02 continental motor for like $500 with 60k. i just don't have a clue on where i should go with this.
Old Feb 25, 2011 | 01:14 AM
Z28KLR's Avatar
Z28KLR
I don't think the Continental engine will help you as it was originally a transverse mounted engine and I think the mounting points are different than 4.6 blocks for rwd cars. If the 03/04 blower will mount onto the 99/01 engine (not sure on that) then definitely go for the Cobra (people usually only have GT's because they can't afford a Cobra) if you can swing it.
Old Feb 25, 2011 | 05:18 AM
uberstang1's Avatar
uberstang1
Chupacabra
As stated above the continental motor will not work, some people say just get the motor mount locations re-worked so it will drop in but its worthless because the bolt pattern for the bellhousing is different as well. The cheapest and easiest route would probably be to find a 99/01 cobra motor.
Old Feb 25, 2011 | 03:12 PM
A.T's Avatar
A.T
what i was thinking, was to use the parts from the continental motor to make a 4v 4.6. i have heard the blocks were different. just wasn't sure about the best and cheapest way to bolt this blower onto something.
Old Feb 25, 2011 | 06:21 PM
BraMas's Avatar
BraMas
almost every post I have seen involving putting a Eaton on a 2V or even a non 03/04 motor have said that for the same $ you could have bolted on a Better S/C made for that certain engine. I'm not saying it can't be done just saying when all said in done is it the right direction
Old Feb 25, 2011 | 08:52 PM
DRAGUL's Avatar
DRAGUL
If you just have the supercharger off a 03/04 and that is the only thing you have and nothing else, you can not just bolt it on and expect it to work. There is a lot more to it then just bolting it on to the motor. It is cheaper to buy a aftermarket supercharger and better performance ,then it is to obtain all the parts necessary to make the eaton work. Also 99/01 cobra motors should be forged before adding any power adders. These motors have high compression ratio. If you do a search you will find posts where people have done this and what is needed.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
