Need help? Not sure if I have a stock motor?
An independent test in 2001 revealed that under hard cornering the 4.6L 2V could be starved for oil with only 5 qts in the crankcase. Because of this report Ford changed the recommended fill to 6 qts, and the dipstick and owner's manuals (download them here) to accommodate the change.
If you drive like a normal person, or even quite a bit more aggressively, this is not an issue--however the recommended fill is 6 qts regardless of the MY or dipstick markings.
Point: Cliff
The increased heat is called heat soak. Engines actually get hotter after they are turned off due to the fluids no longer circulating. Hence turbo coolers where the fans run for a bit after shut down.
As for the heat I lost over 40 degrees under hood when I went from the stock GT hood to the heat extractor Cobra hood. True story!
Yeah, the only 'aggressive' driving I do is just straight line acceleration when getting on a highway. Or maybe a traffic circle, or a highway loop-around on/off ramp and in those cases I'm not reaching the peak of my tires or anything, haha. Would you recommend me adding an extra quart next oil change or just stay with what I've been doing for the past years of my stang?
M3hunter
09-05-2015 03:42 PM
