Whats the most boost you would run with non cooled supercharger?
A non intercooled twin screw will heat soak much faster than a non intercooled centrifugal blower even at a lower psi. Even if you make a certain number on the dyno with it, i'd be willing to bet you that you'd loose quite a bit of that power on a warm summer day. I personally would not run any positive displacement blower without some way of cooling it.
Do not under any circumstances run anymore than 6 PSI NON/IC on a positive displacement blower or you're a fool. Thats A LOT OF HEAT. Even after my car is cruising at 180 F and I park it if you put your hand on or near the blower its hot as absolute hell and IC KBs run much cooler than stock Eaton blowers. Have any of you ever seen what the IATS start looking like with no intercooler on a supercharged engine? Does anybody know what your computer does when IATs get that hot? I'm guessing not. And its even worse if you have a silly air intake that pulls from the hot engine air. Our bottom ends will give out even with 10 PSI I/C. I personally wouldn't run any SC setup without an IC. I think you're mechanic wants to make the cash of two seperate labor charges and wants you to get your foot in the door.
Thanks for all the advice. I guess I will wait a lil longer so i can have the Intercooled setup. I want to do it the right way, especially since I have a stock motor. Would anybody know what the average cost to build up a stock block with forged pistons,crank,rods,cam,ring etc? If I were to build my my lower end up and have whatever head work needed AND I had an intercooled KB, would i be able to push out 500rwhp? Thanks for all the help. Im assuming the cost would probably the same as if i sold my GT and bought a Cobra. I saw one for $15k on craigslist but it didnt state the miles.
On another note, anybody know of Mustang shop that does great engine work? I probably would rather just have my engine built up first, rather than throw a SC on it. With a built motor, I should be able to get at least 350hp right? Thanks again.
Forgive me for my ignorance but a positive displacement blower is basically a roots style SC like KB or Whipple correct. So if i were planning on keeping my block stock and go with non intercooled, it would be best to go with a Vortech and keep it at about 5psi? I say this because the vortech is not a positive displacement blower and will not run as hot and keeping it at a lower psi should be fine with my stock engine correct? Only reason I ask these questions is because I really want some power to my Mustang but I cant afford the intercooled KB and I dont have the $$ yet to buy a forged shortblock. And if i did the buy forged shortblock, then I wouldnt have the $ for a SC. I would be happy if I can just spend about $3-$4k and have 350-400hp at the flywheel. Right now GTR Performance has the non cooled Vortech on sale for $3150. Plus a $700 install. Thats fits my budget. Im asking your opinions becus i dont want to end up with a damaged engine. Also I dont race at the track. I just want a faster car and it will be a daily driver. Thank all you soo much for all the help.
I am running a Vortech set up at 8 pounds non intercooled. Although the car runs fine I can tell now that the weather has warmed up it does not run the same as when it was cooler. I see you live in Cali so weather there gets warm and on a daily driver that would be a lot of stress on the motor non intercooled. My intercooler is going on in a couple of weeks because summer is on its way. Mine is a DD also, but don't run the risk. While they are in there have them throw on the intercooler and call it a day
Anyone crying about non intercooled PD set ups ever owned/driven/installed a positive displacement set up? Or is everyone vomiting what they read online and confusing it with FACTS?
Picture roots as two paddles that are connected to eachother horizontally that are driven by a pulley and blow the air downward into the intake. The compression of the air(PSI) doesn't actually build until the air gets backed up in the intake manifold. There is no pressure inside of the case of the rotor blower. Contrary to the far too often assumption kenne bells are not a "blower" the way that centrifugal and roots superchargers are. They are not "blowers" at all infact.
Picture twin-screws as two, screw style machined rotors that intertwine with eachother and literally compress the air in between the pockets of the rotors. Twin-screws actually mechanically compress the air within the case and discharge the compressed air into the upper intake. The air is compressed(not blown) before the intake manifold - much different than a roots.
Hers a visual.
Eaton Rotor(paddles, blow air into intake)
Twin Screw(Screw machined rotors, compress air within case)
