Question guys. Im on a budget so I need a few opinions. Im putting Im putting in mhs stage 2 cams in a couple weeks. Ill have a couple bucks left in the budget when im done. In your opinion what would be more beneficial to me. A new TB and plenum or a front and back strut tower brace with subframe rails?
thanks guys
Personally i'd do the SFC's and tb/plenum at this point. Do you have long tubes already? You want your car to breath as well as possible now that you have cams.
Short tube headers are worth very little from what i've seen. At least not enough to justify the install, when you could just do long tubes. It's not so much the peak numbers that you'll get with long tubes in my experience (you might get 10 hp or so at the peak) as it is the area under the curve.
