ANY HELP
ANY HELP
When I drive my car for a like 20 min. or longer then shut if off to get gas or whatever. Then start it back up it acts like it is either flooding out or not getting enough fuel but it only does this til I get on it as soon as i start driving it clears up.
^ What he said. You can try cleaning the iac if you want (others before you have with varying degrees of success), but technically it is not considered a serviceable part, meaning that replacement is your best option.
If it's the IAC I would just replace it. Cleaning it does not always work. Very easy fix if this your problem. Although it doesn't sound like the same problem. Does it die or try to die when you let off the throttle or is everything fine untill you try to restart the car?
