gear install prob.
gear install prob.
Ok so I got my new 4.10 gears and i'm doing the install but i've run into a problem . When I put everything in the pinion isn't sitting right , there is a small gap in between the dust shield so when I slightly push forward(away from driveshaft) the gears start to bind but when it is slightly pushed back(towards drive shaft) the gears rotate fine. I used the original spacer from the old pinion so it should work.Also I have used a impact and tightened down on it but the crush washer hasn't changed. What next???
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
