keep bottoming out...please help
I put on some Eibach lowering springs which I love but any small pothole or dip sounds like a small explosion. I spoke to a mechanic today that told me my shocks are working fine. I have OEM shocks on now. The mechanic tells me I should put the original ones back on and have them "heat shrunk" which sounds like b/s.
time for a new mechanic. do not add heat to the stock springs.............. Stock shock and struts will not last on a lowered vehicle. yes they are working but they are overworking. When you get new shocks and struts read the small print and make sure you get some that are for lowered suspension
Another issue is that lowering most any car will make the suspension rougher and noisier, particularly on heavier cars with wide/heavy wheels and tires.
So, depending on the severity of what you are experiencing, it may be "normal"...
lowering
I wanna lower my 02 GT but dont want to bottom out all over? i measured and it has 4" between fender and tire tops so i was thinking eibach sportline kit and shocks struts in a kit any advice on buying a kit???
