Good COP Replacement?
Weapon-X COPS FTW. I love these things. Affordable and quality COPs and no retarded looking oversized COP that requires a bolt to install. My only gripe with the weapon x's is that they could have spent a lot more effort making the gaskets fit right at the top. Due to the angle they really dont make that great of a seal at the top. However as long as you're not a dumbass and you dont spray water directly onto your engine(far too many people do this and recommend it as safe if you "cover your COPS") you're fine.
http://www.weaponxperformance.com/ca...roducts_id=103
Yep you're right. But you get what you pay for. Sometimes people don't really think and try to skimp on really crucial parts. The consequences were talking about are a burnt or cracked piston or worse. Saving $100 on COPS aren't worth having to phone MMR for a new longblock.
thanks for the link i could only find them for ~400. 300 is definately reasonable.
are you both running the weapon X street's or their EFX supercoils?
http://www.weaponxperformance.com/ca...roducts_id=100
I'm running streets. Theres a ton of high power 2Vs out there running stockers with no problems. This and their information about the XCOP EFX's convinced me that until i'm making serious power I dont really need to spend the extra $150 on the EFX's.
I burned up two sets of the EFXs, the first lasted 500 miles or so, the second less than that. The first set started skipping when the engine got hot, and I sent them back and put the stockers in.
The second set behaved to same with a quirk. My regular "coming home" commute includes a 35 mile run on I-95 at usual speeds (80 to 85) and then 3 miles or so at 60 to the beer store. After 2-3 minutes of heat soak at the store the engine would not start, I had to let it sit for 20 minutes before it would fire.
Both times when I took out the W-X COPs they smelled burned. There has never been a problem $$-wise, and they are working on a new, thicker, boot to prevent the arcing through the boot caused by the EFX's VERY high potential...
