Code P0460
I don't know exactly where the wire runs, however I have more than once seen situations where a pinched wire works fine for a while until the insulation deforms and flows enough allow the conductor to short out--might be worth checking to see if there's anything pinched at the steering column...
Cliffy,
Didn't seem like anything was pinched or touching under the dash near the steering column... Any other thoughts? Any ideas on where I could find a wiring diagram? Should I check all my fuses? Just don't know where to look next....
Thanks
Thanks
Here are the instrument cluster diagnostic procedures.
Pinpoint test B, starting on page 413-01-14, is the procedure for tracking down fuel level gauge problems. Section B2 is a test of the sending unit accomplished by substituting resistance values of 160Ω (full tank) and 15Ω (empty) for the unit. You don't need the fancy test box, just go to Radio Shack--they have 'em in 5-packs for $1.19.
They will not have the 160Ω value, so either get 150Ω which will be close enough; or get the 150s and a pack of 10s and use one of each in series. For projects like this my fat old finger prefer the 1/2W components as their larger size makes them easier to handle--but the 1/4W devices will handle the very low electrical load if that's all you can get.
