What To Do First
RE: What To Do First
ORIGINAL: DuckyGt
nope
ORIGINAL: XbcSharpShooter
whats a PI swap? and would a 04 gt need that?
Is the PI swap a direct swap of the 96-98 heads for the 99-04 heads or is there some custom work that go with it? If I use after market heads would it have better outcome?
In my opinion a full exhaust setup is always a nice mod to start with, get some LTs offroad mid pipe and a cat back, get that wicked sound to turn some heads, its one of those mods that just put a smile on your face.
ORIGINAL: TimmyGt
Yes it is a direct swap provided that you get everything (PI heads/cams, Intake), And yes you would get a lot better gains if you use aftermarket P&P heads. Check out Fox Lake Raceing, VT Engines for more info on their heads and such.
ORIGINAL: TimmyGt
ORIGINAL: TimmyGt
where would be the best place to get the PI heads, cams, and intake manifold
BTW, if you really intend to do this, now is an excellent time to do the exaust (you have to take it off anyway to get the heads out), and a great time to do a aftermarket camswap and/or get your heads ported. You already have the stuff out, might as well only do all the work once.
If you do get some ported heads, and cams, and exaust, you will not even think it is the same car when you drive it the first time. 96-98 dyno curves are UGLY and you are likely to pick up 100 + RWHP, or 1/3 more.
