Lean condition
Old Jul 17, 2011 | 05:56 PM
ocpman's Avatar
ocpman
Default Lean condition
I'm working on a 2003 4.6L Mustang with a vortech charger. After the tune it ran perfect. It cam back with a melted plug, no other damage to the engine thankfuly. I installed a wideband 02, and the afr is 14.7:1 at idle, and goes as high as 17 on the meter, plus I hear detonation. fuel presure is at 40 psi. any ideas,
Thanks in advance for any help.
Old Jul 17, 2011 | 10:12 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Under what conditions (load, throttle position, rpm, gear, etc.)?
Old Jul 17, 2011 | 11:28 PM
scottybaccus's Avatar
scottybaccus
Did you upgrade injectors? You may be at the limit of their capacity, at given psi.
I do know that the same injectors will deliver more if you can raise fuel pressure, but you will need to revisit your tune.
Old Jul 18, 2011 | 05:23 AM
Blackvenom01's Avatar
Blackvenom01
the idle a/f is fine but the 17 is scary if thats under throttle...pump pressure might be alittle high for idle...but we need alittle more info man
Old Jul 18, 2011 | 05:50 AM
uberstang1's Avatar
uberstang1
Chupacabra
The idle A/F really wont hurt anything its the underload number that can be scary, my wideband fluctuates between 14-17 at idle.
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
winner99
Oct 1, 2015 01:06 PM
mdg
Oct 1, 2015 07:04 AM
treesloth
Sep 28, 2015 07:03 AM
