Plug Blow Out
Old Jul 25, 2011 | 08:40 PM
02GTman's Avatar
02GTman
Default Plug Blow Out
Well my car died today, blew the plug out of the head, front driver side. Can this be fixed?and does anyone know about what it would cost?
Old Jul 25, 2011 | 09:04 PM
95SHO's Avatar
95SHO
Helicoil will fix it if done right or you could replace the head. Either way it isn't the end of the world. There is something else I heard someone raving about but I can't remember what it was called. I think it was some sort of insert that required a different plug after isntalled. Either way good luck.
Old Jul 25, 2011 | 10:06 PM
masterofthepuppets99's Avatar
the thread repair is called "timesert." i blew a plug once, but luckily the threads stayed in the head and i was able to put a new plug in and drive without issue. if you dont feel comfortable using the timesert kit yourself then i advise you give nick mckinney a call over at modular head shop.
Old Jul 25, 2011 | 10:22 PM
TOMMY01GT's Avatar
TOMMY01GT
I fixed my number 6 plug with a kit from autozone, didnt pull the head, seems to be working so far.
Old Jul 26, 2011 | 05:21 AM
uberstang1's Avatar
uberstang1
Chupacabra
Rob, purple iced, just had his repaired not to long ago and it wasn't that expensive I think it was like 250ish?
Old Jul 26, 2011 | 05:30 AM
02GTman's Avatar
02GTman
Thanks for the replies, I guess I will make a few phone calls and see what the going rate is. I guess I will try a new plug first, maybe I will get lucky.
Old Jul 26, 2011 | 05:45 AM
02GTman's Avatar
02GTman
I have to ask myself, what the hell is Ford thinking when they design this stuff? Either the plugs blow out of the head or the dam things won't come out like the 3v F150's.
Old Jul 26, 2011 | 01:58 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Who last changed the plugs, were they properly torqued?
Old Jul 26, 2011 | 02:05 PM
Sxynerd's Avatar
Sxynerd
The first time I changed the plugs in the 03 as I was pulling out a plug I got a nice surprise along with it. A nice Helicoil. The person didn't use anti-seize on the plug threads and it pulled the coil right out. I still haven't had the drive to really fix it right.
Old Jul 26, 2011 | 04:33 PM
02GTman's Avatar
02GTman
I was able to put the plug back in a tighten it enough to get the car on the trailer. Hopefully a new plug with new threads will do the trick. Cars at the shop right now
and quoted about $150.00. I called the Ford Dealer and they wouldn't touch it because someone else had changed the plugs.
