Steeda Tri-Ax??
I'm looking at getting a short shifter (specifically) the steeda Tri-Ax. I've heard good things about this shifter but I have a few questions.
1- What transmition does my manual 2001 GT have? a T-45? I need to know in order to pick the right Tri-Ax to purchase for my car.
2- Is the steeda Tri-Ax the best short shifter for my GT or is the B&M Pro Ripper better? ...or any other brand
If you do think I should get the Tri-Ax, I just have to figure out which of the 3 or 4 Tri-Ax that Mustangtuning.com sells is the one I need.
I am also going to get 3:73 gears, Mach 1 grill delete, and bullit pedals I think... hopefully I can order it all tonight
are you sure? because I just found this on Mustangtuning.com a second ago..."If your build date is 2/01 or later you have a 3650. Before that is T45. Build date is located on driverside doorjam."
Mine says 2/01 so wouldn't I have the 3650?
mungodrums
Sep 28, 2015 10:54 PM
Sep 24, 2015 09:18 PM
Sep 16, 2015 07:53 PM
