Top 5 front front suspension options!?
When choosing to beef up (stiffen/upgrade) your front end suspension what 5things in order would you buy? Basing it of a rear end that would have LCA's, PHB, TA, Quad shock and UCA delete, and 31 spline diff/axels and a good shock/spring combo if there are any ideas on that? It would help too. Mostly daily driver/street/little quarter mile. I have read the suspension stickys.
1. ?
2. ?
3. ?
4. ?
5. ?
6. A good rear end spring/shock combo?
1. ?
2. ?
3. ?
4. ?
5. ?
1. ?
2. ?
3. ?
4. ?
5. ?
1. ?
2. ?
3. ?
4. ?
5. ?
300lb coil overs in the front and their torque arm springs in the rear is the spring rates that I run
http://www.maximummotorsports.com/st...oducts_id=1065
There's no real order in which to do the front suspension. But usually, people lower their cars first. In that case, you would have to do these 5:
1. Lowering Springs
2. Caster/Camber plates (may not be needed depending on amount of drop)
3. Struts/Shocks
4. Bumpsteer kit
5. Swaybar
Focus on both the rear of the car and the front. Also get some nice FLSFC's.
1. Lowering Springs
3. Struts/Shocks
4. Bumpsteer kit
5. Swaybar
+1 on the FLSFC
Going completely off what MM Techs have told me several times... no need for Bumpsteer kit unless you change a suspension mounting location.
I am still wondering about Steeda X2 balljoints and then a bumpsteer kit??? Anyone know for certain?
+1 on at least 300# CO's up front, but may want a bit heavier. I used to run them on traditional CO's and compatable ride quality to your average OEM located lowering spring. What are you running out back for springs/shocks?
CC plates ~ Definitely, regardless of CO's or not, as a bit more caster is probably needed.
Bump-steer ~ probably, if lowered
Sway bar ~ maybe? Depends on your understeer/oversteer situation
FLSFC's ~ Definitely
Jazzer
Jazzer
lol i already got FLSC's i should update my signature. A couple more qustions
1. so is getting front and rear blisten HD series damper (shocks) with a front spring rate of 300-375 and a rear spring rate of 250-325 would be a good start?
2. followed by coil over kit? or should or do you have too install all at once
3. Also if i was planning on CO kit i would have to purchase CO springs? and can you use CO springs with out a CO kit?
4. LCA, do you NEED perch and sway bar mount? i was looking at MM LCA. Should i go with non adjustable or adjustable
Are you going to go CO's out back?
If so, a 300# is a good match for a 300# CO up front. This is what I run out back, but run a 750# SLA CO up front.
Jazzer
Jazzer
what is a 750# SLA CO? short long arm? can you give me a link or example of what you are talking about casue you just said 300 springs in front and back
1. so is the shock sitting inside the spring on a CO? and then theres another the regular shock? i sound dumb posibly
