Change pistons/rods with heads on motor
Is it possible to take out the rods/pistons with the motor out of the car but the heads still attached? The reason i ask is because i might possibly need new pistons and/or piston rings and i JUST spent $700 on new tty cobra head bolts, head/intake gaskets, etc, (no more than 75 miles on them) and id like to not have to unbolt the heads again since those bolts are 1 time use.
What happened to your pistons/rings in 75 miles of driving since the heads were off?
damnit man... no what happened was car overboosted or something, detonated/lifted the heads and blew out the headgaskets. changed out the gaskets car runs good now but theres extreme amounts of blow-by, most likely rings or cracked piston(s)/ringlands. will do a compression test but im 90% sure since its puffing out the oil fill cap.
Id think you would be pushing out of the back if it was a piston/ring.
I had an AMC 360 with 1/2 of the top of the piston crown missing with most of the top ring visible...that ran fine with no blowby or smoke...so if you are getting blowby, id expect some smoke.
Id wonder about a possibly warped head or something like that...A leakdown test will tell the story.
well there is smoke, comes out the valve cover breather and out of the oil cap. heads are fine, not only were they freshly decked about 1500 miles ago with the new motor, but i just rechecked the surfaces at the machine shop and pressure tested them as well they were good to go.
Sorry Man that sucks. Although I have to say I'm so very pleased not to have these problems anymore, lol
My buddy ended up smoking 3 motors in as many years making 500rw and he just had to pull the motor again because of a blown head gasket. He's got about 4k miles on all three motors combined.
I finally finished mine, put 1200 miles on it, parked it and dismantled it. Crazy sure, but nobody was going to drive away in my blood sweat and tears. lol
