5 happy minutes before a KB smackdown
I just installed a big tube kit and a 14 lb pulley. Nailed it a couple of times on the highway with a nice response. When I got off the highway I could hear the belt smacking the hood. It looks like it jumped a rib towards the charger and ate 1 rib. Anyone else have similar issues? I know they push the 8 rib swap for anything over 14 psi.
My Procharger did that regularly till I switched to a double shoulder pulley. It would often slip off by a rib, hit the alternator then go flying off. At $60-$80 per belt that sucked quick. See if you can find an alternate pulley design. I have a couple pictures around if you need to see what I am talking about.
tensioner is snug, didn't hit the limiter, made boost (13 psi).
I put my spare on after filing down the closest obstruction I saw. There is a stud and bolt for a wire loom near the pan. Seems to be doing good now.
Uber - I just use the KB canned tune. I don't have a forged crank and should be pushing the limits with the conservative tune they flash.
Shadow - that sounds like the way to go. Can you send pics? I wondered why KB doesn't send them that way.
Thanks, I'm sure you guys are right. I'm new to boost and have put a wideband in so I can at least see whats happening at full throttle. I guess I was going by the lit from KB and the fact that they discourage dyno tunes. Everyone says u can get more out of them with a dyno tune. I wouldn't want some jack leg tuning the car, got any suggestions for tidewater VA?
On a related topic my bud was taking his ls1 to the track the night after I changed the belt. I told him before we got too far I would need to crack it a couple of times and look under the hood to avoid a long tow home. I did a drive by and he said it sounded like a 747 was landing on him, then he sucked fumes through his recirc ac for 5 mins. Got to the track and it was shut down from an earlier sprinkle. GRRRRRRRRRR!
ya KB is on crack if they discourage dyno tunes...yes there tunes are "ok" but my belief is that tune is just to get you from the shop to your dyno guy with no heavy acceleration...a dyno tune can see what your car is doing and make adjustments they cant see that unless you send them data logs then thats just a KB dyno tune
my suggestion is to find a couple places around where you life and go there one weekend and watch him do some cars...everyone is gonna try to sell you on something but the guy that talks about what he does with passion is most likely a good guy
hopefully someone on here can suggest someone for you!
