Question about Nitrous system
Overview: When the nitrous solenoid is opened (its an electric solenoid) the nitrous flows through to the jet and into the intake or where ever it is plumbed.
How to: So you have to send power through the solenoid when you want it to open and spray the shot. Note that a wet system also adds a fuel solenoid. There are 3 basic options available.
a) Manually with a button you have to press and hold.
b) Mechanically by having the accelerator pedal or the throttle shaft to trip a micro switch when you step on the gas.
Or c) Electronically controlled by tapping into your TPS sensor and picking up the wide open throttle signal from there.
If you decide to go with a system, i'd highly recommend either NX or NOS. I'm not saying the others are bad, but i hear nothing but great stuff coming from these guys. I run NOS personally. I've had it for over 3 years, and haven't had one single issue.
Sep 10, 2015 08:39 PM
