my car wont run need serious tech experts
Ok after a pain in the *** ride home im having serious issues with the car it seems when ever I gett on itt before it can get boost the wideband spikes 10.0 and I smell raw gas and hear my sc bypass valve go crazy.
It also does it when I let off the gas as well. But idles fine and cruises fine. Had similar issues when the vacum line to the bbypass went but its def good this time. Im trying to get some ideas. Fuel pressure reg? ,
Mass air flow? Vacum issue and where and why? Tps? Fowled plugs? All air hoses are connected and vacum lines are ggood?
Starts up as normal as long as it didnt previous stall, if it fuels out and stalls its hard to start. I don't think its an o2 wire because it runs and drives fine as long as its not WOT or engine braking.
Heres a question I bet cliffy can answer, is there a way to test the FRP before i just go throwing money on parts that might be good, can u put a pump on it and check to see if it holds pressure and if so what kind of numbers should it put out?
Best bet is to get a known good one and change it and see if your still having the same problems.
i am running a Kennebell FRPS disc saved me money on buying another FRPS
