01 Cobra - 03/04 Super Charger Upgrade
Old 09-26-2011, 01:28 PM
GalaxiePete
GalaxiePete's Avatar
Default 01 Cobra - 03/04 Super Charger Upgrade
I am wondering what parts are needed and what is involved. If someone who has done one or for sure knows I'd appreciate your input. I am looking at an 01 and there are a lot of stock super chargers floating around out there really cheap...
I mean, would stock or aftermarket 01 TB, Mass Air, etc work? I am guessing is it going to need different brackets, etc. But does anyone know what part numbers? Most of the SC engines are being sold complete so getting parts might end up with a run to the parts department.
GalaxiePete is offline
Old 09-27-2011, 07:03 AM
Chris98Gt
Chris98Gt's Avatar
Pm darkmach1 he had an eaton swapped mach1. Should be a similar setup to an n/a cobra.
Chris98Gt is offline
Old 09-27-2011, 09:34 AM
LilRoush
LilRoush's Avatar
The blowers are fairly cheap... but you need the top third of the motor: lower intake to airfilter, all the intercooler/HX lines and related parts and a few misc upgrades. Just make sure you know what you are getting into before thinking it's cheap.
LilRoush is offline
Old 09-27-2011, 01:11 PM
school boy
school boy's Avatar
go check out svtp forums. there is always a kit floating around there. also check out the 'new edge cobra' section of the form for details on the install
school boy is offline
Old 09-27-2011, 02:45 PM
DRAGUL
DRAGUL's Avatar
Use the search.I have read multiple posts that say, you are better off going and buying a aftermarket kit. Just remember the 01's are not forged motors like the 03/04's are.
DRAGUL is offline
Old 09-28-2011, 10:47 AM
GalaxiePete
Thanks for the input guys...
Dragul - I thought all Cobra's had at least forged cranks. I know Rods and Pistons are another story.
I am trying to determine if it is a Teksid or WAP block at the moment. I don't know the manufacture date of the car at the moment and haven't actually looked. But either way it SHOULD hold what I want. I am looking for a target of 425 rwhp. Anything in the 400-450 range will do. I believe when I hear that magic 500 hp number on a stock motor that people are usually referring to rwhp. If not, I will probably back down a little to a 400 rwhp goal.
There are a lot of inexpensive kits now. I don't mind a used one in good shape. The Vortechs in particular are cheap used. Is there any particular reason? I mean I suppose it is because there is less to them. But they are also not as popular as they used to be in the good ole push rod 302 days.
Old 09-29-2011, 01:10 PM
Chris98Gt
Chris98Gt's Avatar
I Believe the 96-98 cobras had the teksid blocks, while the 99/01's had the wap blocks.
Old 03-15-2012, 12:47 PM
1966vietnam
1966vietnam's Avatar
I have a 97 Cobra. Would it be a lot of work to install a super cherger? Expensive?
1966vietnam is offline
Old 03-15-2012, 11:19 PM
SVTeeshirt
SVTeeshirt's Avatar
Holy thread revival, it will be a decent amount of work and run you $2000 MINIMUM probably more.
SVTeeshirt is offline
PaulH2
20
01-31-2016 09:48 AM
88 orangepeel notch
10-05-2015 09:03 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: 01 Cobra - 03/04 Super Charger Upgrade
