Do i have a pi head...
Old Oct 18, 2011 | 01:17 PM
djd2392's Avatar
djd2392
Default Do i have a pi head...
So i opened up the maintence manual for my car today, and i saw the last owner wrote everything down, and i stumbled across something that caught my eye.. the entire intake manifold was replaced at 30,000 miles in june of 1999, and so i started wondering..do i have a pi head? I took a pic of the aluminum cross over, and i had heard that that's a way to tell. is this true?
sorry if this is kind of a stupid question, i just never knew how to tell the difference haha
Old Oct 18, 2011 | 03:20 PM
amoosenamedhank's Avatar
amoosenamedhank
You can install a PI intake on NPI heads... so that doesn't mean much.
Old Oct 18, 2011 | 04:26 PM
JRad405's Avatar
JRad405
I'm pretty sure my car has an NPI intake with an aluminum crossover. So you may not even have a PI intake.
Old Oct 18, 2011 | 04:37 PM
djd2392's Avatar
djd2392
I shouldve worded the thread better..i shoulda asked do i have a PI intake manifold
Old Oct 18, 2011 | 04:43 PM
03gt04mach1's Avatar
03gt04mach1
Your engine probably still has the original heads. It's just the intakes on the earlier 4.6 engines had problems CRACKING and leaking anti-freeze. That's why there is aluminum where the coolant crosses over, instead of plastic. But you do have the UPGRADED Intake though.
Old Oct 19, 2011 | 09:01 AM
amoosenamedhank
It's hard to tell from you picture but I have a picture of my PI intake and NPI side by side.
Do you see how the NPI intake (the one on the left) has a threaded hole on the coolant cross over above the thermostat housing? That is because the NPI intake has 2 coolant sensors/senders and the PI intake only has one (which is on the passenger side of the coolant passage.
Old Oct 20, 2011 | 07:55 PM
01GTvertible's Avatar
01GTvertible
The aluminum crossover needed when doing a PI swap is under the lower intake. You can't see it unless other intake manifold is off. It runs from the back of the water pump to I believe the head.
BacusJason02GT
Nov 7, 2014 02:51 PM
mith
May 15, 2013 04:12 PM
DSargent09
Jul 13, 2012 09:01 AM
Mr. D
S197 Shelby Section
64
Dec 19, 2011 03:58 AM
